Overcoming the biggest laundry dilemma
24.06.2024
How much detergent, which program and how to dry?
Have you ever found yourself standing over the washing or drying machine, with clothes in your hand, wondering how to make the best decision by pressing the right program? Wondering if you should pour a little more or maybe rather a little less liquid detergent? On the second thought, should I rinse the whole wash again? Luckily, Hisense has put an end to overthinking about the right laundry decisions. The new Hisense series of washing and drying machine 7S comes with intelligent sensor system that automatically matches the perfect washing and drying cycle for your laundry. Let them make the hardest decision instead of you, so you can enjoy in always perfectly clean and dry clothes. Amazing, right?
Innovations for stress-free laundry
Technology driven approach to solving your problems has been the core of Hisense brand from the beginning. When you live a busy life, making important decision every step of the way, it is important to rely on innovative and reliable home appliances, as washing and drying machine, to take care of your laundry seamlessly and efficient. Eliminating dilemmas is the key, so you can always rely on the best results. Smart washing and drying means easy living, therefore you can control and manage your new washing and drying machine via an intelligent TFT display or from anywhere and anytime using ConnectLife app on your smart phone.
So, how does the intelligent washing machine work?
The intelligent sensor system in the new Hisense 7S washing machine analyses the laundry inside the drum and chooses the best treatment to get the optimal results. AI Super Wash therefore automatically matches the perfect wash cycle for your laundry by weighting and sensing loads. No more guess work and no more detergent dilemma. Smart Dosing automatically releases the quantity of liquid detergent needed to efficiently wash the clothes. This feature helps you to fully utilize detergent and save each drop to reduce waste water, protecting the environment. All you have got to do is pour the laundry detergent into the container approximately once a month and let the washing machine do the rest. The container can store up to 24 loads easily.
Why choose the intelligent drying machine?
The new Hisense 7S drying machine assures you easier, smarter and better drying thanks to AI Super Dry. Once you put your freshly washed clothes into the drum, the innovative sensor system senses the level of humidity of your clothes and cleverly picks the correct drying cycle automatically. It does not stop there, as the machine monitors the temperature and humidity during the drying cycle, stopping it when your clothes are perfectly dry to prevent them from being overspun.
The key to innovation is communication and efficiency
Welcome to the next generation of laundry, where the washing and drying machine talk to each other to save you time, energy and money. Incredible, right? The intelligent synchronization between the appliances is called Smart link, where you simply pair both appliances via Wi-Fi. How does it work? Once the laundering process is finished, the washing machine sends the current washing program to the dryer. Based on the received information and sensor’s analysis it intelligently decides how to dry the load by choosing the right program.
Optimized decision making between the washing and drying machine saves you extra steps, therefore saving you time as well as your and electrical energy. Minimal costs and high energy efficiency are one of the key benefits of choosing the new Hisense intelligent 7S laundry appliances. Guaranteeing you A-20% energy class means preserving even more electricity compared to top tier A class. Prepare for lower electricity bills and taking a step towards helping with the environment. Explore the next 7S generation of laundry at hisense.com.
