Autentificare sau înregistrare
How to store wine at home
27.05.2024
A guide to maintaining the quality of wine
Drinking wine is a beloved ritual. The hard work and love that go into creating a bottle of wine should be celebrated with every drop that excites our tastebuds. Whatever is your wine of choice, right storing is just as important as making wine and it can make a huge difference even if you aren’t investing in the most expensive bottles on the market. To help you keep your wine in the best shape we have prepared a guide to help you maintain its quality.
1. Keep the right temperature
Temperature plays the most important role when storing wine since too warm or too cold conditions can decrease the quality of wine or even make it go bad. While it does depend on the type of wine, in general ideal temperature should be around 13°C. The temperature should remain stable, also so the cork doesn’t change shape. The temperature should never drop below -4°C, which is the point at which it can freeze, or go over 20°C which accelerates the aging or destroys certain compounds. To make sure you create the best possible conditions Hisense JC-122W Wine Cabinet uses modern No Frozen technology and employs fans and heating components to circulate cold air, that it creates steady conditions and prevents formation of ice and frost all while being energy-saving. Furthermore, the Wide Temperature Range of 5~20°C is expertly crafted so that it can fit even the most temperature-sensitive wines while the Temperature Compensation maintains a steady temperature even when external temperature fluctuates.
2. Ensure proper humidity
You might think humidity doesn’t play a role since wine bottles are made of glass, however, it can leave big impacts on the cork and consequently on the content. When the cork dries out wine can be affected by oxygen and flavours can escape, while too high humidity causes condensation and mold to intrude. To prevent that humidity should be kept between 50 and 80 %. Precise Humidity Control in JC-122W Wine Cabinet does just that while an innovative self-evaporation system manages condensation and keeps the inside of the cabinet dry and pristine.
3. Keep away from odours
They say that “wine breathes through the cork”. That also means odours in the room or cabinet can get in the bottle and decrease the flavour and aroma of its delicious content. But not with Hisense Wine Cabinet! Using specially treated Activated Carbon Filter it banishes unwanted odors and enhances wine’s aroma.
4. Store in the right position
When storing for longer, cork should remain moist to prevent aging. Therefore, wines should be stored horizontally. JC-122W Wine Cabinet has beautifully and usefully crafted trays with wood trim wire racks that can keep 46 bottles placed in perfect position.
5. Protect from light
UV rays can damage the quality of wine since it effects aroma and flavours. It is therefore important to keep away from sunlight. With Anti-UV and low-E glass Hisense wine cabinet protects your bottles from rays and temperature fluctuations, by also reflecting heat energy. To further protect your bottles, it uses Adjustable LED Light that also enables you to create the perfect atmosphere tailored to your mood and style.
6. Store according to wine type
With JC-122W Wine Cabinet you don’t have to choose between different types of wine with different storage requirements. Thanks to Dual Temp Zone this cabinet allows you to create different storing climate in upper and lower zones while Extra Door Seal ensures the air doesn’t mix and flavors don’t blend. If you want to find perfect conditions or learn more about your wine bottles use our Wine Library that we created in collaboration with the Vivno app. Simply scan the label and discover everything about the wine with your personal sommelier in an app.
7. Protect from shaking or vibrations
Vibrations disturb sediments and that effects wine aging. This can be caused by near by vibrating appliances like dryer or stereo system or even working out. Hisense wine cabinet uses Low Vibration - innovation, specifically designed to reduce vibrations within the wine cabinet and Soft-Close Wooden Shelves made from the finest wood that minimize vibrations and provide a quiet and smooth handling experience.
8. Keep it in style
Ok, this one is not really a necessity, but if you treasure a good wine, you want to handle it with respect it deserves. Hisense JC-122W Wine Cabinet is not just a practical but an elegant choice as well. Modern design perfectly fits into any existing kitchen design and ensures easy handling through Touch Electronic Control or ConnectLife app, which enables you to monitor or change conditions even when you are away.
BACK TO TOP
