The step-by-step guide to choosing the right air-conditioner
15.3.2022
Bigger is always better, right? Not when it comes to air conditioning. Too powerful, and you get uneven cooling with super cool spots near the device and hot spots in corners. Not powerful enough, and the device will get overworked while still failing to reach the desired temperature. In both cases you get higher operating costs and underwhelming results. The secret to success is getting the AC cooling capacity just right. Here is the step-by-step guide to help you find the best air-conditioner for your needs.
Step 1: Measure room size
Step 2: Define other factors
Step 3: Calculate AC capacity for your home
Step 4: Choose the right type of AC
Portable air conditioners are more suitable for small spaces, as they usually have cooling capacity around 6.000 to 8.000 BTU (1,7 - 2,3 kW). They are incredibly easy to install & move as they do not require any mounting and are cheaper than other AC devices. If you still want strong cooling but don’t want the hassle of installing split AC to the wall, the Hisense Portable-G is perfect for a breeze of fresh air in any room. It comes as a multifunction AC, fan and dehumidifier and provides stronger cooling than most other portable AC devices, with cooling capacity of up to 12.000 BTU (3,5 kW).
Now you are all set. You know which type of AC you need and how much cooling capacity it should have. The next step is start exploring your options. Discover the whole Hisense air conditioning range and find the perfect AC for you.
