How to efficiently use the AC in the summer
29.6.2021
Summer is already here and so are the high temperatures, that call for vacations and a refreshing jump into the sea. But since most of us cannot enjoy relaxation on the seaside through all hot months, AC becomes our best friend during the days we have to spend inside, especially if we have to be productive. But do you know how to make the most out of your air conditioner?
What is the best temperature?
It is generally recommended to keep your room temperature at 26 °C. Not only can low temperatures effect your well-being but making the air conditioner run a lot lower can result in it wearing down faster, and of course higher energy bills. Even if you want cooler air faster, setting the AC on lower temperature will not cool down the room any faster. Since the general rule is to set the air conditioning 4 to 6 degrees below outside temperature, Hisense offers advanced air conditioners with AI Smart function, that automatically adjusts inner temperature, humidity, and wind speed to weather conditions outside your home. To ensure optimal comfort in every part of the room they also come with 4D Auto-swing (horizontal and vertical swing), Ceiling & Ground Airflow and Long Distance Airflow that optimize the distribution of air, and create every spot the sweet spot. Besides that, they introduce fresh and purified air at a rate of 50m3/h which means they refresh the room in just 3 minutes.
