How to use Air Conditioner in Winter
22.12.2021
Winter is here and so is the cold. And as much as we enjoy walking in the winter wonderland, building a snowman, skiing and sledding, there is nothing nicer than coming back to a warm home and curling up under a blanket for a cozy and warm night in. Did you know that to achieve that, you can use an air conditioner? To show you why they are such a great winter choice we have answered some of the popular answers about using AC in winter.
Can you use every AC in winter?
That depends on your machine and environment. Check the manual to make sure running your air conditioner in cold weather is fine and make sure the temperature is not below the one stated in the manual.
For what can you use AC in winter?
If your air conditioner comes with heat mode, you can use it to warm up your home. On the other hand, some Hisense air conditioners come with Fresh Air function as well. This function takes fresh air from the outside, brings it through layered purification and spreads it throughout your home.
Air conditioners also remove moisture from the air, they are however not as efficient at it as dehumidifiers. If you want to really get rid of that condensation on the inside of the window and prevent mold from developing in your home, you can get a Hisense AC that works as a humidifier as well.
